UKSupertrucks
Hi, Possibly a 'low value' question but, is it common practice to re-use the power stering fluid cooling loop, that is factory fitted to the pump return pipe on the LS400, or loose it. I have just transplanted the LS400 engine into a 1997 Hilux double cab - that did not have one as stock, but then thought that the Lexus one might be a more powerfull pump, that might require the fluid to be cooled. Any advise from experiance appreciated.
Thanks
Thanks
