Hey Gang,
I have been doing lots of research on stand alone and the price is just too high and too complex for the average end user. The question we need to ask is why do we need stand alone? There are many answers to that question. One of the most important answer would be able to control huge injectors for huge boost and especially important during idle.
Here is what i got. Stand alone range from 2k to 4k (complete) and possible 1-1.5k for installation and tuning. I dont know about you guys, that is a lot of money.
So, what is the solution if you want high boost and dont want to about 5K on the electronics? Here is my solution and its my plan. Split Second piggy back can control both fuel and timing. This unit also can incorperate an external MAP sensor that will allow boost up to 32 psi. With 32 psi in mind, those poor 550 cc injectors will not have enough juice to support the potential huge hp from the boost. Split Second also made an extra injector controller that will allow up to 4 individual injectors.
For example, if i run 8 550 cc with the piggyback and run 4 1000cc with the extra injector controller. The total of cc will be 8400 cc and it means about 1050 cc each. With 1050 cc/min (each cylinder) it should able to support huge hp for you crazy guys out there.
From my personal experience and i am not endorsing anyone. The R4 program can be learn in few clicks and the wiring is very simple. The cost of the equipment is as follow:
1. FTC1: $500
2. Injector Controller: $350
3. 3 Bar Map Sensor: $60
4. Extra Injector Clip: $240
5. Installation: Self
6. Tuning: Self
The total about is about $1150 and capable of controlling 8400 cc/min. What do u think?
Below are two map tables of my setup. The first partial map is for the Fuel and the second partial map is for timing.
1. FTC1: $500
6. Tuning: Self
