JamesN New Member Apr 11, 2008 #1 My fog light just died out and can't seem to source out the problem. I check for bulbs, connectors, and fuse. All seem fine. What next?? Switch?:uh: Any ideas would be appreciated.
Lextreme II Active Member Apr 11, 2008 #2 Use a volt meter and see if there is power or ground. If you have power and ground then it might be the plug/contact or light bulb.
JamesN New Member Apr 12, 2008 #4 I can't find where the relay for the fog is. So I tap the wired to and fix it for now.
