What is Blue Smoke Mean and possible cause/s.
1. Signs of oil burning
possible causes= Bad rings, valvestem seals, headgasket, crack
in block or head(s), turbocharger or supercharger seals,
malfunctioning PCV system
2.
3.
What is Black Smoke Mean and possible cause/s.
1. Signs of improper fuel mixture and or burn
Possible causes= Injectors, injector wiring, engine managment malfuction
(fuel and or ignition), improper tuning, fuel pressure regulator
malfunction, to large of a fuel pump
2.
3.
What is White Smoke (not to be confused with steem from condinsation in the exhaust during cold startups) Mean and possible cause/s.
1. Signs of water/coolent burnig or vaporizing (also excessive fuel that cannot burn most notorious with excessively (fuel) flooded motors)
Possible causes= Headgasket, cracked block and or head(s), over
excessive water injection if being used, any item that has a water
port adjacent to a intake or exhaust runner (examples, throttle body
warmed, ISC solinoid warmer, EGR cooler, ect.) leaking liquied to air
intercooler if being used
2.
3.
