What do you think gang? Single pipe power a T3/4. Once it hit a preset boost like 8 psi or so, the actuator will open up and feed exhaust energy to the second T3/4turbo to take it all the way up to what ever your final boost is.
There are few exhaust bypass out there we can use. Most of the exhaust bypass uses actuator and control my vacuum. However, this bypass also can be accomplish by a large wastegate. Once the wastegate open, the second turbo kicks in. This is almost like the Surpa's Sequential...
Beside the twin T3/4. I guess you can also do T3 for the first stage and T60 for stage two too. Whatever combination you like. For example power band would be Low to Mid, Low to High, Mid to high and so on....
Benefit, low end boost and high end power.
