I'm pondering upgrading my 1UZ valvetrain, since we'll be putting in some Lextreme Stage 1 reground cams, and I understand this motor has a tendency to spit shims after cam/spring upgrades. After fixing the problems in the bottom end, I really don't want to start having cam/valve problems. So the way I see it, I have the following choices:
Stay with shim over bucket - not a good idea IMO.
Shim under bucket options:
2UZ buckets & shims
RB26 buckets & shims (a la Paul Carey)
Possibly 3UZ buckets & shims?
Shimless bucket options:
SZ motor (Prius & Yaris?)
Any others?
Appreciate any feedback from those running any of these combo's. I know Erol is running the shimless bucket setup with lash caps on the valves, but is planning to do something different soon.
BTW, did a shim bank ever get established in the USA? These puppies are expensive @ nearly $7.50 each..... Even if we do have a shim bank, it's probably for the shim over bucket setup, and I'm sure the shim under bucket setups are different <sigh>.
2UZ buckets & shims
Any others?
