C claxby New Member Aug 7, 2024 #1 Have a 5 speed in a Landcruiser conversion , there doesn't seem to be a shift lever release wired into the brake light switch , I have to use the over ride button to move from park to drive...hope you understand the question. Thanks in advance.
B blinkerfluid New Member Aug 9, 2024 #2 So you know the problem, you need to wire the shift release mechanism
C claxby New Member Aug 12, 2024 #3 blinkerfluid said: So you know the problem, you need to wire the shift release mechanism Click to expand... Absolutely....is it the same latch used as the override latch is what I should have asked, as I haven't looked yet.
B blinkerfluid New Member Aug 13, 2024 #4 Is it indeed, but its a levered mechanism operated by a solenoid - when you press the brake pedal the brake switch sends +ve to the solenoid.
