My transplanted motor doesn't run right.
Was running real good after i got it wired up. Perfect in fact.
Now it takes a few scary goes to start. It fires terribly on the first few start attempts then when you get it to go it runs a bit ruff then perfectly.
The rev counter does bounce around erratic witch is accompanied with some slight misfiring . This is intermittent with no real regularity.
Even when it is hot and you try and start it again it takes a few goes?
It is a 95 celcior motor running the factory computer with a manual box it is the late style airflow meter type.
Has anyone experienced this type of thing?
