Secondary Engine stabilizer
Hi All
Has anybody added a stabilizer to the engine, I was thinking of somewhere at the front from the power steering mounting bolt to the chassis, My engine seams to have a bit of movement even with new mounting blubbers.
Alan
How good is the gear box mount ??
Not knowing your car as I'm more into engine tech..
We have run a flexible belt as you said from engine to solid
strong section on body like cross-member with a little slack..
Belt as in seat belt, tie down strap..
Hi.
Gearbox mount new as well, I was thinking of one like I have on my Subaru, it has polly bushings on each end and supports the engine and gearbox from the top end, like this one, the smaller bolt hole will slide on where the power steering pump was,
Alan
Yep know that bracket well..Should help..Although I would have set so it "shares" load with std mounts..
