stevechumo
I'm just thinking about how much horsepower I will gain for doing these upgrades on a 1995 SC400.
1) A cold air system that I plan to cut a hole under the stock air box position and run a full custom intake pipe and its filter down underneat. I might use the Bypass valve by AEM, which eliminate the water sucked in the engine. I believe it'll make more hp than the short ram or stock air box. How much hp will I gain?
2) 2 MSD 6AL ignition boxes that gives more sparks. How much hp will I gain?
3) A full exhaust system including the hi-flow cat-converters in the upper part, with no big cat in the middle like stock, and 2 resonators near the rear mufflers. I will still use the stock headers since I don't want to haul the engine out. How much hp will I gain?
Any info. is greatly appreciated.
