Hey
Question is simple:
What is needed to make stock sc400 ecu work with manual transmission?
I was reading much about that. Perhaps that is opportunity to put that knowledge in one topic.
Till now I read:
Pin 14 on plug 3 should have 12v. That is neutral switch. So ECU will thinking tranny is neutral and do not look at difference in vss1 and vss2 signals. Correct?
I want use r154 from supra mk3 transmission. What about speedo signal?
My r154 have speedo cable (mechanical) and I think it is useless for sc400 ECU. It have one vss sensor (electrical). That is all. IS THERE SOMEONE WHO DONE THAT BEFORE? Is that will work? or maybe I can buy speedo sensor (toyota dealer) from JDM r154 soarer and just use it?
What else is needed to make stock sc400 ECU will work with manual transmission?
Thanks
Jerry
Question is simple:
Till now I read:
Thanks
Jerry
