radicalblurr
I have a problem with my battery draining. It will sometimes hold a charge over night then other times it will drain within an hour or so. The CD changer also behaves erratically, but i have tried unhooking the CD changer and the amps, i have also pulled the main fuse for the stereo - not the secondary 7.5 amp fuse yet. i recently purchased this car and it has a new antenna and the CD & tape buttons won't switch sources on the stereo. is it possible that the stereo is draining the battery? also i noticed that the remote door lock stopped working as this problem became more regular and never noticed that the security light ever came on when i shut the door. i have also turned off the remote lock switch since i read that it could drain the battery.
can anyone give an opinion?
my next step is to remove the stereo entirely to see if that helps, if not i'm afraid that i will have to go connection by connection to locate the drain.
1994 SC400 btw.
1994 SC400 btw.
