folashade96
Hello. I'm in the process of installing a piggy back ecu on a 1994 LS400. All connections are good except for the RPM signal. I've tried connecting it to a fairly large yellow wire on the end wiring loom (NE+ I believe) and it reads rpm fine when set to 2 cyl mode but stops reading correctly after 1200 rpm. I tried connecting it to a black ecu wire which I believe was either G1/G2+ and those wires are reading about 8000-9000 rpm. Does anyone know which wire is the proper one to get rpm signal from on a US 1994 LS400?
