Anthonygrud
As the title says im going to be doing a 1UZ swap into a S13. Im most likely going to go with a sc400 1UZ so i can run electric fans. Im going to be using a kit that comes with all the mounts for motor and transmission. Ill be using the stock KA s13 transmission and ill have an adapter plate made by a friend. Im not sure of the flywheel , pressure plate , and clutch set up so if you have any information it would be a huge help. Also if anyone could supply information on the wiring for this that would awesome.
and yes i have searched around and i cant find any information on the wiring and clutch problems.
Thanks , Anthony
Thanks , Anthony
