s13/1uz power steering pump/rack question
Im in the middle of a 1uz-t swap in my s13 and im wanting to see if anyone has used the 1uz power steering pump with the s13 rack? Does it work or does anyone have any experience with miss matching pumps and racks that could help me out? Thanks
Glad to hear it. That saves me from having to make custom brackets and pulley for the s13 pump and probably a custom length belt. So basically all I would need would be longer lines and hydraulic fittings to fit the new pump then?
yessir. that's all. it works even when doing the ls1 swap. it seems like all of the mfg's seem to use right around the same line pressure and flow rates.
I found a kit sold by xat racing that is a bolt on conversion for the 1uz to s13 rack for $175. I'll probably be going that route for simplicity reasons
