Hi guys I have just gotten my 1UZ hilux going, using a UZS131 Crown engine and ecu, with 5 spd manual.
When started it will warm up and settle down to an idle speed of 600revs, which is good. After a drive around the block, the idle will pick up to around 1000 revs and sound a bit lumpy.
I Currently only have extractors with O2 sensors near the end, Could the lack of back pressure be causing it to run lean?
Also, check engine line comes on and gives codes 42, 83, 84 and 85.
Any help would be appreciated.
Cheers.
Cheers.
