Rotary gear change
Hi All
Anybody looked at replacing the standard gear shift and link rod, I saw a rotery switck in a hotrod mag and he just used a 5 position switch and some led's, any thoughts on this, I would think its only wires to the ECU
Alan
The shifter is connected to the gearbox by a linkage.
The lever moves a shaft that runs into the gearbox.
You could replace the linkage with a servo motor and some micro-switches but I could see it being a lot of work.
