Replacing crankshaft oil seal
ca12los
I am having a hard time trying to replace the front crankshaft oil seal as well as removing the camshaft pulleys to get to those Camshaft oil seals also.
Any advice on anyone who has venture here without the special service tools???​
The cranks seal i just popped out with a screwdriver after i revomed everthing, and then found a piece of pipe the same diameter as the seal and tapped it home.
Sorry havent done the front of the cam seals so i cant help you there.
Hey guys,
I managed to remove the cam seals pretty easily. My crank seal looks in good shape and I dont want to mess with it fearing that I could reinstall it incorrectly. Thanks for the advice nonetheless.
