Great news! I talked to few Lexus Tech about removing LS400 exhaust manifold. They all stated that the passenger side would be easy, but the driver will require the whole engine to come down or out.
I examined this problem and JBrady was discouraged due to this complexity of replacing stock exhaust manifold to his custom made header. Due this fear, many potential buyer was turned off. However, its great news for JBrady and many others.
Here is what happened.
1. Remove the cats and the primary O2 sensor
2. Remove the Steering joint and along with rack & pinion
3. Loosen the engine mount bushings (both side)
4. Remove the driver side engine mount
5. Remove the exhaust nuts
6. Remove the exhaust studs (VERY IMPORTANT)
7. Use a jack to jack the engine up
8. The header will come right out.
Once the stock manifold came out, its time for my single turbo header to go in. So far its bolted on and tomorrow will be the big day for the completion of the diy project........
