tdcoup New Member May 14, 2006 #1 any1 know how to wire up a remote start? the car came with 1 but for it to pass R.A.W.S laws it had to be taken out.
T Tigssc400 New Member May 29, 2006 #2 wiring 92 sc400 WIRING INFORMATION - LEXUS / SC 400 / 1992 / Remote Start 12volts white & white/red + ign. harness Starter black/white + ign. harness Ignition black/yellow + ign. harness Second Ignition black/orange + ign. harness Accessory pink/blue + ign. harness Second Accessory Keysense Power Lock green/yellow - pass. kick panel Power Unlock green/white - pass. kick panel Parking Lights+ dk. green wht. plug in dr. kick Parking Lights- green/blue steering column Door Trigger red/white - wht plug below fusebox Trunk/Hatch Pin red/white/silver dot - dr. running board Trunk/Hatch Release black/silver dot + dr. running board Factory Alarm Arm common with lock Factory Alarm Disarm green - driver kick panel Notes: Single (-) pulse disarms without unlocking. Tachometer a/c grey wire ignitor, driver's strut tower Brake Wire green/white + brake peadl switch Horn Trigger green/red - steering column IT IS YOUR responsibility to verify any circuit before interfacing with it using a digital multimeter
