Am I correct in saying that to setup the 1UZ FE with original ecu,fuel pump ecu,hydrofan ecu that
1 Main EFI relay would run EFI+Fuel Pump+HydroFan all togther..?
2 Ignition relay runs starter motor and ignitors..?
I'm guessing I could setup each with there apropriate amped feed individually but is this necessary..?or just have enough feed amps to run them together as in the diagram..?(i'm just checking justto make sure i get this right.(i don't want to have every relay coming off just 1 or 2 feeds is all-that would mean i would have to have around a 100+amp feed to do so..right?fused of coarse..)
Ive been going over and over the SC diagrams and all it shows is these relays and feeds going to these relays..let alone of coarse the rest of the harness..
seeing as i now have the motor ecu+hydrofan ecu+ fuel pump ecu could this work..I just need to know how many amps to run to the apropriate relay.cheers
