Kaktus
Hi lads,
I am planning on eventually putting either a 1uz or a 3uz in my Triumph Stag (when the body is more or less sorted), and due to the location of the front crossmember and steering rack on the Stag the only realistic alternative is fitting either engine with a rear sump as that just about should clear the crossmember.
Considering I should quite easily be able to find an LS400 or LS430 as donor car, would the rear sump and oil pickup fit without (or minimal) modification from an SC400? Or would anyone have a better solution to the problem (dry sump too expensive)?
Thanks a mill in advance for any comment or suggestion!
