OK notice where you have dropped 111 rwkw from your number? OK..
Secondly, there was a Soarer converted to 5 speed manual here and dynoed, and it LOST a couple of horses. What is so "power taxing" about the A341? Yes it is soft, but that is just the shift logic involved. The planetary gear set in it is about the same inertial load as a pair of shafts of gears in a manual box, and when the converter locks up, that's locked up like a manual's clutch.
The Viper must be doing something right - yes it is a 2 valve engine, but stock it dynos about 415rwhp. Halve that and you get 207rwhp. Which is more than my space age 1st gen V8 Soarer ever did AND the Viper does it with a lower compression ratio. Tell me how they pull that off.
The US Honda website says the S2000 is actually a 2.2 litre engine with 11.1:1 compression ratio and an 8000rpm redline, with its power peak at 7800rpm. It also shows the S2000 as having an UNDER square engine. Previous years I believe were almost square or very slightly over, and actually peaked at 8300rpm with a 9000 redline.
The 8L Viper is over square, has a fuel cut redline of 6200rpm. The redline on my car is 6250. Many have raised the redline on the Viper by 500 or 750.
The title of this thread is actually "light build-up of 1UZFE". That does not involve dropping in a 4.3. Yes, by changing engines you might get near 300rwhp.
I had a quick read of the threads you posted. We have:
262 with exhaust, intake, ECU
255 with same
249 K&N intake
249 K&N filter
230 stock / with exhaust
From your post, I was expecting to see "270 with no exhaust". What I see is a car with 262 with everything except (maybe) extractors. Which may add another 15 or 20 if they are REALLY good. I have seen a lot of headers and extractors put on cars. The best results I have seen was a set that cost in excess of 2500 US dollars, put on a Viper, and yielded mid 40s hp with exhaust. These were tuned length, lots of work done, real science. And they yielded just over 10%.
I hear a lot of people saying "get a really well designed exhaust and you'll pick up 50hp", but I don't see anyone doing it. Please prove me wrong. The fact is most people pick up 15hp with the first one they put on. For some that is the exhaust, for others it is the headers. Then people say "sweet, they add 15 each". Then 15 becomes 20, and 20 becomes "25 if you use a lot of science". The results are usually what Peter Scott shows. 15 for the first, and half that for the second.
