danielwrich
I have an inboard ski boat that I'm setting up with a 1uz running a soft clutch setup and will be running in fresh water, I want to run a raw cooling system that picks the water up from pickups in the hull and runs it through the block.
My question is should I remove the water pump turbine and leave pulley, or run it as well as a external pump to supply water pressure to the block
