I read the communication you had with Marlin, not good. If you have not solved your problem with your speed sender I found the senders from from late model Toyota Prados and Landcruisers will fit a r154 gearbox and W58 as well. They go straight in and instead of a clip holding them in they use a bolt, so easy. They use the same three pin plug to connect to the harness
Warren
