Hey guys;
wired up a 1uzfe (jdm) with a 92 ls400 harness and ecu;
I've verrified the circuit open relay, and both efi relays are working correctly. The coil to caps are both hot when ignition is on, and in start position. I don't have much more than an ohm meter for diognostics (picking up a better spark light and an injector light tomorrow) but best that I can tell I'm not getting any spark...
Only things it could be is cap, rotor, or wires right?
I see there are plugs going to the base of each distributer, are they involved in any way with something that could cause this issue?
I spent all day working on it and have a feeling it's just a cap or rotor issue, but it seems odd both banks would be bad, but I suppose sitting in a crate with salt water vapor would do that?
Idk, any help would be very appreciated
