Hey all, I need some expertise in confirming that my planned drivetrain will work.
I'm planning on mating a 1UZ > A340F bellhousing > Adapter plate > R151F
and using a flywheel from a 3SGTE with the bolt patterns machined out 10 mm, a hydraulic throwout bearing from an AX-15 trans, and just the stock R151F clutch.
Will this all work? I'm a little unclear on the clutch/throwout bearing area...
Thanks.
Thanks.
