![DSC_5958.jpg DSC_5958.jpg](https://www.lextreme.com/forums/data/attachments/16/16248-2272bbd0ead535cd9047d184606f28a5.jpg?hash=InK70OrVNc)
I participate mainly in the a MR2 forum that does not have content spidered by Google, so you won't see any of the info there pop up on Google searches. As a result, many of you might not be aware of my project.
I am introducing, to you all, Project MV8R (named after the SARD MC8R LeMans MR2)
I have a 1993 turbo (my turquoise car) that will eventually get this powerplant after I get the bugs worked out. I am using a 1991 (red) MR2 as my test mule. My 93T is in beautiful condition, and my 91na is...........not
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
Anyway, the gist of the project is a Northstar V8 + GM F40 6 speed manual tranny, and hybrid GM + MR2 axles.
I know it has been suggested on this forum, as well as MANY MANY others that a 1UZ-FE v8 from a lexus should be used. This is impracticle for many many reasons. The biggest reason is that it is simply too long to fit the 2nd gen chassis (and probably the first gen too). The front pulley would have to be inside of the tire. It just ain't gonna happen, folks.
Acutally, it could, but only if you want to build a whole tube frame for the rear of the car, and re-engineer the whole back of the car, and you must mount the motor longitudinal. In this case, the Lexus is not ideal, as the front of the motor would be in the cabin.
I decided to take a different approach. I went and tried to find an engine that would fit the mk2 transversely. I found one, the Audi ABZ, but found this engine was not suitable mainly because it was never offered in a transverse application, so Audi inconveniently put the block skirt, the starter, the oil pump, the oil pump drive, etc. in the way of the intermediate shaft and right axle.
Mike_H on the MR2 forums has done the World's First V8 2nd gen MR2. He used the Audi 4.2 V8 (engine code ABZ), and mounted it longitudinal. He used this engine because its around 6.5 inches SHORTER than the 1UZ. The Audi is 20.63 long, the 1UZ is around 27 inches. The N* is 23 inches long and required some cutting of the chassis, when I bolted it to a transaxle that is shorter than the Toyota MR2 turbo trans.
So, I decided to use the N*. This is an ongoing project. The N* now fits the car (a bit of cutting was required, but not as much as you might think).
______
CBulen
Project MV8R: Sign up for the build manual
