I got this turbo from SSAutochrome and I am somewhat disappointed with this product. SSAutochrome Ebay Ads and Negative Feedback for SSAC It stated as follow:
BRAND NEW
GT35/40R BALL BEARING TURBOCHARGER
.82 A/R EXHAUST
.70 COMPRESSOR
DUAL BALL BEARING -
.82MM COMPRESSOR WHEEL CAPABLE OF .64 Lb/MIN AIRFLOW
BOOST AT 2700 - 3500
OIL AND WATER COOLED
INTERNAL WASTEGATE @ 12 - 16 Psi
I got the following measurements:
Compressor:
Large impeller: 3" (76mm) Advertised as 82mm
Small impeller: 2.070" (52.5 mm)
Turbine:
Large impeller: 2.780" (70mm)
Small impeller: 1.834" (46mm)
Compressor Inlet: 4"
Compressor Outlet: 2.5"
When i got this turbo, its NOT BRAND NEW. Its recondition turbo. There are many scratches on the turbine impeller and discolored. Secondly the actuator bracket and actuator doesnt mate with the internal wastegate. Basically its useless.
When i free spin the turbo, there is a grinding sound. To verify the impeller size, i also noticed the compressor impeller doesnt spin properly. The alignment is off and it doesnt spin straight.
I guess i get for what i pay for. I will ask for refund due to deceptive advertising. Here are some pictures.
BRAND NEW
.82 A/R EXHAUST
.70 COMPRESSOR
DUAL BALL BEARING -
Compressor:
Turbine:
