OK here it goes, about 4 months ago the problem started with it feeling like my fuel was cutting out while i was driving but the car would still run. Then the car started dying out, i would pull over and try and start it. It would turn over for like 2 seconds then die again. After about 2-10 tries it would start and run fine. The problem progressevly got worse, then one day it would'nt start at all and all i did was loosen fuel line from FPR and started the car and shut it off. The car ran fine for about 3 weeks then the same problem came back. I was totally convinced that it was a fuel problem. This is where it gets funny, i started tapping the FPR with a wrench and the car would start. that seemed to always get the car started so i assumed the FPR was no good. After purchasing one from the dealer here in Hawaii for just about 200 dollars the car still did'nt start. The next day i went outside to uninstall the new FPR and the car started and ran fine, so i left it in. I drove the car around all day problem free. The next morning the car would not evan start. So i took the new FPR out and tried somthing else. I changed the fuel filter and the fuel pump, that only seemed to work for about a day or so until the problem came back. The last thing i have tried was bypassing the fuel pump ECU and that worked for about another day until it craped out on me again. I really don't know what to do already at this point. Oh yeah i've also cleaned the idle control motor, and i've changed plugs,wires,caps, and rotors. So can someone Please help me, i would really appreciate it...thanx in advance,Vince
