Ok, some of you may be familiar with my car, some not, so here's a couple of links.
Lextreme http://www.lextreme.com/forums/showthread.php?t=8757
Club Lexus http://clublexus.com/forums/showthread.php?t=312268&highlight=boosting+projects
I've had quite a few problems along the way and up until now, I've always managed to figure them out. I am very stumped on this one, I don't know what else to do.
Car: 95 Lexus SC400 with V-9 vortech supercharger. Non intercooled with the piping ran outside of the engine bay. About 135k on the odometer.
Problem: With a COLD start, my AFR stays at about 14.5 to 1 while at idle and while cruising. Goes lean with boost. Doesn't matter if I drive the car 2 miles or 20 miles, the idle and cruise AFR stay at about 14.5 to 1. With a HOT start, the AFR starts out at about 14.5 to 1, but then starts to go rich after about a minute of running, down to 12.5 to 1. Still goes lean with boost. Also, fuel cut operation seems kind of funny, ok at higher RPM's but pulses rich at lower RPM's.
Testing, parts changing:
I've tested and changed a million and one things, which I'll go over, but this first thing is kind of interesting.
With the car HOT, I shut it off, then start back up, AFR is normal. As stated above, slowly goes to 12.5 to 1 after a minute or so. If I disconnect the MAF while the car is running, the AFR stays at 12.5 to 1. When I plug the MAF back in, the AFR goes to 14.5 to 1, then does the same thing, goes down to 12.5 to 1 after a minute.
I figured out that my FPR was leaking vac / boost, replaced it, no difference.
I did some testing on my fuel pump, seemed a bit shady, so I replaced it with a high flow Walbro. No difference.
I checked my fuel pressure, about 40psi at idle. 50psi with the FPR vac line removed and plugged. And..I saw as much as 65psi while blowing air into the FPR with an air gun. This all seems normal.
I have removed or bypassed the charchol canister, the VSV for the FPR, and the power steering idle up swith. No difference. My EGR is and has been blocked for a while now, since before this problem. The only thing, that I am aware of, that is still connected to a vac source is my boost gauge, the heater control valve and the FPR (without the VSV). I've checked everything for leaks, can't find anything.
I took out my plugs, cleaned them. No difference.
I changed some of the piping before the MAF sensor to 3inch. I did have 2.5 inch all the way up to the MAF with a 2.5 to 3 inch coupler on the MAF sensor itself. Didn't make any difference.
Unplugged all of the O2 sensors, no difference. Normally, I have all the sensors installed except the drivers side front sensor, this is where my wideband is installed and is where I'm getting all my readings. I've thought that maybe my wideband is reading funny, but the AFR readout reacts as it should during testing. Shows leaner if I pull a vac line for example.
Within the last year (before supercharging), I have changed the coils, wires, caps, rotors, t-belt, all the fluids and a few other things I'm not remembering at the moment.
I checked every single wire between the ECU and the MAF and TPS sensors. Also checked for shorts to ground, no problems found. Checked the IAT sensor, good.
I plugged the throttle body side of the PCV hoses, no difference.
I've unplugged the coolant temp sensor on the radiator, no difference.
I'm sure there is a few other things I've tried, but I can't think of them all.
I'm really at a loss here. I'm assuming that the lean with boost and HOT AFR decline to 12.5 to 1 are related, but I'm not sure. The only other thing I can think of is an IAC problem. The car runs smooth otherwise, so I wouldn't think it could be a mechanical problem. I also don't suspect injectors, I think I'd also have other issues. Like I said, I'm really at a loss.
Please help!
Thanks for reading my novel.
Khris
Please help!
Khris
