Hi guys
I'm having a lot of trouble locating a diagram for my ECU, its a 89661-50170 (34-22-16-28 layout) from a UCF 1X Celsior. http://www.toyodiy.com/parts/xref?s=89661-50170&mJ=on&mG=on
The loom had been wired for a later (UCF2X) ecu that didn't match the motor and I am now just trying to verify if my 28 pin plug is wired correctly as I have found there are differences between the years and I am unable to start it. At the moment I have this:
# 9 grey IGSW 12v w/ ignition
#13 green-red MREL 12v out to EFI relay
#14 black-yellow BATT 12v constant
#16 BK brake pedal
#22 and #23 B+ 12v out from EFI relay to ECU
I seem to have fuel pressure (fuel pump primes) and I have spark but it only cranks, won't fire. Even on aerostart.. Oddly enough I did have it running with the 28 pin plug (only) wired in its old config and plugged into the old (ucf2x) ecu but cannot get it running on the single ecu with the new config (nor the old config). Basically just moved MREL from #24 to #13. Logic tells me its something to do with powering the efi or ecu as thats essentially all that's changed since I had it running with the 2nd ecu piggybacking? The only error code I get is 78 - which is traction control or something (not running it, don't care)
It's in a hilux too
If anyone has a suggestion besides burning it, or knows where I could find/buy the diagram for this ecu please let me know!
Thanks!!
#16 BK brake pedal
It's in a hilux too
Thanks!!
