rx7 s1 1uz
i got my 671 supercharger and manifold yesterday had to sit it on top to see what it looked like . still need to get it all polished and add my bugcatcher on top.
and if any 1 has any good ideas for a injector setup and fuel rail. here is my problem in pic #3 i have only got 60 mm between the manifold and the top plate that the 671 sits on (note you can add approx 5mm down to were the injector seat is) and then to top it of in the middle were the rocket cover bulges out it only clears by 20 mm (can angle the manifold top plate to make it to approx 30-35mm
would need to use something around 550cc injectors as i am looking at around 23-25 psi im guessing it will end up around the 700 hp mark
Im in New Zealand and i know that there is a maximum hight that you can have a engine component sticking though your bonnet (i know its in relation to your window hight) iv asked LTSA and few other places but no 1 can seem 2 give me a answer for it. if anyone in New Zealand can help me with the answer to that it would be a grate help (so that i can get a cert for it)
