spf_lexus
So I have had a miss on my car thats been around for a while. I think the farthest back I can recall it was my engine rebuild, and it hasn't ever fully disappeared even after new plugs/wires/caps/rotors. I was checking out my cam trigger wheel on driver side at idle and noticed that the entire pulley was slightly bent, yeah bent. It was very slight but enough that the small "tab/trigger" was visually massaging a couple mm. This would explain the random miss most frequent on inclines and certain part throttle. i want to say I have some contact but; my guess is the ecu is sending signals to increase output to the plugs but the contacts are not spot on and are not producing whats needed. Possibly ECU trying to correct? The car always gets it's groove but it totally feels like something is lagging behind. I usually need to lay off very sightly to get rid of the miss, but this is of course is once i have already reached cruising speed for whatever hill i'm climbing.
