Hi, I have a UCF11 Celsior engine in a HX tonner with factory auto and ecu.
It is running ok but has what appears to be a rev limit when in park/neutral, it cuts at 2500 and returns to idle before picking up again.
This doesn't occur in gear and was doing it in the front cut also so I assume it is normal but would like to confirm that it is.
Is it possible to remove this as it seems to be a fairly useless feature and also puts the engine light on when it occurs, this goes out once you put it in gear or cycle the key.
Any help is appreciated.
