Oxygen Sensor
From what I understand all single wire sensors work on the same principle and produce a similar output.
The differences between engines is the way they attach. The wire/plug out the end is easilly swapped.
Why not go into REPCO with a sample and see what they have.
I'm about to do the same with one of mine.
If you don't have any I can lend you a sample as I'm also in Sydney.
