One busy engine bay
gloverman
Well-Known Member
Just a few teaser photos.
Here's an engine bay where you're hard pressed to "spot the Lexus"
At least with the one I'm working on you can still see it is a lexus in there unlike your rover Rod.
It happens to be a Series 5 RX7 fitted with twin TD04 turbos. We have been doing the wiring of a link G4 storm and then tuning. Its been running for two weeks now. Before it goes onto the dyno we are making some powersteer lines , brake lines and clutch lines. Its taken a couple of days to do the powersteer so far. Its about a 4 hour job to get the radiator out and back in to enable us to get at the powersteer rack. Brake lines tomorrow. Ill get some dyno sheets when its tuned.
It runs
Yes well a week ago it had its first drive. The week before we spent some time making powersteer line which was interesting and then making up brake lines and setting up the master cylinders. The owner spent some time finishing it off and it had its first drive. No boost but it was a drive. A bit of checking of the stuff and it was backed onto the dyno. Some photos to follow and Ill try and post the first power run after the initial tuning
Customer took it for his first drive today. It goes nuts. Ill try to post the dyno sheet.
It's a factory convertable and thats about where the "factory" end. Not sure what the final weights going to be. It has a mazda speed bodykit to go on which looks really good when on. Im looking forward to when the customer has it all back together. My work is nearly done. Cheers
Heres the dyno sheet. 8psi. It is just crazy for a stock motor with small turbos.
