Hey All,
Long time reader first time poster.
I need some help in working out what is wrong with my 1uz. I have a ma70 supra with a 1uz that my father and I made about two years ago.
Car has run brilliantly for the last two years but now its not going so well.
I did a timing belt change and a shim replacement.
There was an issue with putting the timing belt back on, i got it one tooth out on the passenger bank. But after realizing that I correctly aligned it. in replacing the shim i took the intake cam out.
After doing those two things it nows runs rough on the passenger bank, you can take a spark plug lead off and nothing changes, but take a lead off the other side and its noticeable.
First thing i assumed was incorrect timing on that bank. but i checked the marking and it all lines up. ignition timing is fine as well.
checking error codes on ecu, it said o2 sensor, i have replaced both with genuine ones, still problem, but ecu says its all fine.
i check resistance readings of all cam and speed sensors
swapped igniter's around
tested wire continuity and shield grounding.
changed plugs.
I am running out of ideas,
Please help me, i can usually fix things on my own but now i am really stuck.
thanks in advance for your responses.
changed plugs.
