Mat, it's a slippery slope you're on, asking about oils
If the engine has been on a diet of dino oil prior to your ownership, putting a synthetic in is liable to find some leaks you didn't know you had, plus you may find you have worn valve guides and/or hardened & leaking valve stem seals (smoke on starting, deceleration, etc.)
Not to say you shouldn't try it, but just have your eyes open going in.
I've always liked Mobil1, but having said that, I'm running Redline in the Ferrari based on a recommendation by a Ferrari tech that I have a lot of respect for. He felt the shear strength of the Redline was superior to the Mobil1 and would work better for the Ferrari motor in our hot Houston climate. Being in the UK, that's not a consideration for you
I've forgotten what the recommended oil is for the W58's, but I know for the V160 in my Supra, nearly anything that guys tried other than the recommended V160 oil caused issues either with shifting, or seal swelling. Redline, in particular, was NOT recommended to be used in the V160 because of the seal swelling. (The BMW crowd had similar problems with the Getrags in their cars.)
So, based on all this, I'd say you could do a lot worse than Mobil1's line of products.....
