Oil pressure switch questions
converted
Hey guys, with the standard oil pressure switch, does the ECU need to see the oil switch?
The reason why is that I have replaced it with a Mercruiser unit to suit the gauges in my boat. Will I need to put the standard one in line somewhere in the oil system for the engine to work?
Oil pressure switch does not go to the ECU so no problem there.
Early 1uz will be fine without O2 sensor although they do not run their best without them. The late ones will fault code.
What year is your motor?
