EyesofThunder
Anyone know if there is any place I can get oil from, not a lot, just for a bypass oil filter. Typically oil pressure sender is chosen, but wondered if there is any other place. Many of the GM engines in trucks or HD applications (LT1's) have factory oil cooler lines fittings built into the block. Did Lexus/Toyota do that?
Where is the oil pressure sender? Is it easy to get to?
I only need a 1/4" line or so, not much.
