Hi all,
I want to wire the oil pressure gauge on my 1uz. I've got the stock pressure sender, but a VDO oil pressure gauge I'd like to use (or I will use any other if there is a known one that will work accurately).
How do I work out what gauge to get? Do they have a standard for volts vs psi on the sender (and on the meter)? Or failing that, can anyone name a type of gauge that will work with the stock 1UZ sender and give an accurate reading?
Thanks, Mat.
Thanks, Mat.
