I have seen leaks from the tappet cover gaskets , Spark plug seals ( these are the ones in the centre of the tappet covers), the oil filler cap, the cam seals, the front crank seal , the rear crank seal , the blanking plugs at the back of the cams in the cylinder head , the oil filter housing , the oil pressure switch , the oil filter itself , around the main sump pan, around the lower steel sump pan , the sump plug , the dip stick oring, from behind the engine front cover ( oil pump) and even seen oil leaks from the head gaskets. As this is pretty much every gasket and oil seal on the motor I would suggest you get some degreaser and a water blaster and give it a clean and see where the oil leaks out.
Ive also had one leaking oil (and water) from a hole in the centre of the valley and another from the hole in the side of the block but I think its pretty safe to say your leak isnt from there.
And the most common leaks are generally caused by old seals and gaskets so this doesn't really apply to a rebuilt motor. Did it get a little bit of sealant at the base of where the tappet cover gaskets go over the cam caps? Cheers
Did you leave any out ??? LOl...
Yea mainly cam covers and front / rear main seals...
Haha.
Well yeah the rear main seal is the big one that's common and hard to replace.
Any of the seals which see movement can go, or high pressure points.
Amazingly my 1uz with its 75,000ks still hasn't leaked from the rear main seal.
Although Ill replace it when the next gearbox goes on.
Where are the most common places on a 1UZFE that leak oil?
My engine swap leaks oil and of course drips from the lowest point on the engine making it difficult to spot where its coming from.
Use fluorescent oil dye:
http://www.motoiq.com/magazine_arti...-finding-oil-leaks-using-fluorescent-goo.aspx
When u find the leak, use shelllite ( white spirits ) to clean surface , to apply new sealant.
Brake cleaner tends to leave a " white crust / salt"
