I have a 1UZ and it is driving nuts!
No problem until you really rev it, then it leaks oil from the rear real bad. I changed the rear seal when doing some other work and also sealed up the flywheel bolt as some oil was getting past those.
I'm wondering if anyone has had anything like this? The oil is coming from the rear r/hand side. I am guessing it may be coming from the sump seal? Although that is just sealant, I suppose it could leak?
There isn't a breather problem as far as I can see.
So, any ideas? Anyone else had this?
