krayn
Hi all. I have been fitting up the engine and the oil filter is in the way. I took the oil filter extension off and turned it 180 degrees and sat it back on. It will now clears the chassis where it was fouling as the oil filter extension does not come straight out of the motor, it comes out on an angle. Has anyone else done this and had problems with oil leakage as using it this way you can only put the 2 nuts back on and are unable to use the bolt to hold on the extension. If it works it saves me from doing a remote filter set up. Cheers Kris.
