Oh Crap, what did I break??
Spinnetti
I was working on my 91' LS400 (race car) and removed the traction control because it only worked for a short while on the race track anyway. I took it all the way out - the TPS, Servo motor, butterfly - everything. I also pulled the fuse.
Now the car won't start. It turns over, but won't fire - it ran perfectly before this... PLEASE help if you know how to fix - I assume I triggered some fatal fault code or something? I have a race next weekend and am desperate to get it running again....
Thanks!.
Have your tried putting the fuse back in? Did you clip the wires from the sensors or just unplug them? Cheers
Thanks.. I think I got it... When I had things apart, I broke the plastic intake so I replaced it with silicone and tube. I left off the cold start air bypass, thinking it wasn't that important, but it was (I've done this on other cars with no problems). If I floor it on starting it fires right up but won't idle - I'll re-enable the bypass and it should be ok I think....
