Jake Breyck
Wiring Conversion for 1uz into a MA71 (Non Turbo) Supra.
Warning: it is very likely that there will be Major differences if the car and engine are not from the same years as mine. I used a 91 supra and a 92 1uz.
Warning 2: I'm not a wiring expert, and i take no responsibility for something that may go wrong on your car, You are on your own
This wiring how to is only to get the car running, it does not include ac. or gauges. as i did not hook those up on my car. If anyone would like to add this information please feel free
You will need your fuse box connector and dash connector cut from your 7m engine harness.
Fuse box plug:
Cut the Fuse box connector from the 7m harness and cut off the 1uz connector and wire the 7m connector onto the 1uz harness as follows.
Lexus V8 wiring harness MA71 Fuse box
Black / Yellow Black / Yellow + Orange bands
Black / Orange Black / Orange
Black / Red Black / Red
These two wires come out of the harness with the fuse box connector, Extend them back around to the ecu plug to use with the next step.
Black (Extend to Dash connector)
Black / Orange (Extend to Dash connector)
Cut the dash connector from the 7m harness and also remove the 1z dash connector and wire the 7m connector as follows.
Ecu to dash connector:
MA71 Dash connector Lexus V8 Dash connector
Gray Black / Orange + Silver bands
Black / Yellow + Silver bands Black / White + Silver bands
Red / Black Red / Black
Orange / Black Orange / Black (Extended from front of engine harness)
this wire goes to 2 places...
Black / Blue + Orange band Black (Extended from front of engine harness) And Black on ecu plug the black wire is the 4th wire from the end on the bottom row on right side of the ecu. I dont have a picture of this yet but i will.
Alt:
The alternator is very easy, the wires are the same color on the 1uz alt harness as they are on the 7m harness but the alt is located on the opposite side of the motor, extend these wires around, ran mine along with the headlight harness that runs under the radiator support, this way the wiring is well hidden and away from moving parts on the front of the motor. remember use a heavy gauge wire for the main alt power wire. adding in a connector is a good idea as well if you ever have to take the motor out, i scavenged off a 3 wire connector from another harness.
This is also mirrored on my website at http://www.jakebreyck.com/Articals/1uzwireing/
Fuse box plug:
![fuseboxconnector.jpg](http://www.jakebreyck.com/Articals/1uzwireing/fuseboxconnector.jpg)
![dashconnector.jpg](http://www.jakebreyck.com/Articals/1uzwireing/dashconnector.jpg)
Alt:
