Danger Mouse
Hi, new to the forum, joining as I've recently bought a '91 2WD Hilux with a 1UZ conversion, done professionally for the previous owner (mostly a very good conversion, but needed a couple of things tidying up in the wiring).
Currently also has an intermittent misfire (yet again I stop lurking and actually join a forum only when there's a problem), but only started doing this the last couple of days and need to spend some time under the bonnet testing leads, checking plugs and the like. It's running the stock ECU, so can also check fault codes... but if anyone knows a "first place you should check", apart from continuity checks and plug cleaning, it would be much appreciated. I've done plenty of searching already, so got some great pointers (ah I do love forums...), if the weather isn't too shocking this weekend I'll give her a once-over.
Other than that, hello!
