4camSC
Hi ya'll,
I've got a '97 sc400 that I swapped the engine from a 94 LS400. I swapped the engine to OBDII with the sensors/wire harness/cams etc. from the newer engine. After getting it together I could not start it. Upon closer examination, I found no spark, check engine light on the on position, or fuel. I then tested my FP with 12 V and it worked fine. Before I swapped it, it ran (sort of, due to the previous owners abuse). I thought it was the ECU after checking the cam and crank sensors and the ignitor's ground. Well, after further research I put power to the B+ pin and to the FP and managed to get it to run (roughly).
Any thoughts on why the fuel pump and the ECU won't come on unless jumped?
