Stil nothing ![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
Here is what I've done.
Tested resistance in both cam sensors , and crank senors, all 3 are in spec
Tested volts at those all were right under 5 when key is on
Tested ignitors and coils both good
Jumped signal wire from ecu to ignitor and got spark coming out of coil
Ran new wires from ecu to ignitors just to make sure
Tested continuity in all the core A wires including earths/grounds got info from this>>
http://oldschool.co.nz/2011/forum/i...ow-to-wire-up-a-1uz-engine-vvti-and-non-vvti/
For those who care.
34 pin connector
Pin. Tested
12 -ignitor signal Good
13- sta Good
14-nsw. Good
24- IGT Good
25 IGT2 Good
26. Igf2 Good
33. Ground/earth left. Good
34. Ground earth right. Good
22 pin connector. Tested
5 Ne+ crank. Good
6 ne - Good
10 g1 camleft. Good
11 g1- Good
16 g2+ cam right. Good
17 g2- shares g1- Good
22 earth not to motor BAD added new ground now good
16 pin connector. Tested
16 ground. Good
28 pin connector. Tested
9 ecu power. Good
14 constant power. Good
22 +b ecu switched power. Good
So the only thing it can be is the ecu not sending signal to ignitor?
And the only reason left is the ecu is bad?
Because sensors are good and wires from sensors to ecu are good
And wires from ecu to ignitors are good
For those who care.
34 pin connector
Pin. Tested
13- sta Good
14-nsw. Good
24- IGT Good
25 IGT2 Good
26. Igf2 Good
5 Ne+ crank. Good
6 ne - Good
10 g1 camleft. Good
11 g1- Good
16 ground. Good
9 ecu power. Good
